80mm rim Q's
Posté : lun. févr. 28, 2011 05:46
par SkR8Pn
Hello,
Can standard width coaster hubs be used with 80mm rim?
Thank you
Posté : lun. févr. 28, 2011 09:35
sure !
of course you can ! the standard size for a coaster hub is close to 100mm
Posté : mar. mars 01, 2011 12:27
par SkR8Pn
Kanar a écrit :sure !
Thanks Kanar,
also would this mean that you could use standard hub with a 10mm spaced rear sprocket plus slight offset lacing of the spokes for 100mm rim?
At the moment i only understand how to lace spokes into wheels, im not to good on calculating what spokes, hubs and rims yet........ :oops:
Thanks again
Posté : mar. mars 01, 2011 08:27
somewhere in the CB forum, you can find some help to calculate spoke for your rim and hub. If I remember, this help looks like a Excel Software.
I'll search that for you !
Posté : mar. mars 01, 2011 09:32
Hey !
Check here :
http://www.gillesberthoud.fr/supporttec ... rayons.php
there is a red link "fichier" to an Excel Worksheet.
Thissheet calculates the spokes you need depending on the size and diameter of the hub, the number of holes, the diameter of the spoke head and the number of desired crossing.
another help right here :
http://dl.free.fr/jxMyVFvw8
http://dl.free.fr/q1QU3eHFQ
http://mgagnon.net/velo/roue_montage.fr.php
I'm sorry, everything is in french :/
If you have any problem to translate, ask to me !
Posté : mer. mars 02, 2011 03:41
par SkR8Pn
Thanks Kanar
I appreciate the time you took to help me with the links for the spoke calculator. I just hope i take the right measurements to use the calculator.
merci :D
