RHL Mobzter
Posté : mar. sept. 23, 2008 02:01
pas nouveau mais voici un nouveau montage de notre amis du canada
le systeme de fixation de la selle qui es juste a pleurer
http://WWW.RHLKUSTOMS.COM
vlan dans les dents
Here's a customized RHL Mobzter build that I'm doing for a Children's dentist here in Canada. He wanted a cool cruiser that he could display in his dental clinic whenever he's not using it and the kids would be able to have their picture taken with the bike if they choose to
The bike uses a Mobzter framework as a base with a wide bottom bracket, 170mm dropout rear hub spacing and custom made seat mounts. I fabricated a metal panel insert in the frame to display the dental clinic's logo. The frame will be painted a simple gloss black base/clear to serve as a base to set off the purple accents on the bike. Rear wheel is a 24"x100mm with a 24"x 4.1/4" tire and the front wheel is a 24"x80mm with a 24"x 2.15" tire. The wheel will have a purple to black fade color. The seating is a way cool looking custom made black leather and purple metal flake vinyl motorcycle bobber seat.
More build pics to come....
vlan dans les dents
