80mm rim Q's
80mm rim Q's
Hello,
Can standard width coaster hubs be used with 80mm rim?
Thank you
Thank you
Thanks Kanar,Kanar a écrit :sure !
of course you can ! the standard size for a coaster hub is close to 100mm
also would this mean that you could use standard hub with a 10mm spaced rear sprocket plus slight offset lacing of the spokes for 100mm rim?
At the moment i only understand how to lace spokes into wheels, im not to good on calculating what spokes, hubs and rims yet........
Thanks again
When in doubt.....CHOP IT.....
Hey !
Check here :
http://www.gillesberthoud.fr/supporttec ... rayons.php
there is a red link "fichier" to an Excel Worksheet.
Thissheet calculates the spokes you need depending on the size and diameter of the hub, the number of holes, the diameter of the spoke head and the number of desired crossing.
another help right here :
http://dl.free.fr/jxMyVFvw8
http://dl.free.fr/q1QU3eHFQ
http://mgagnon.net/velo/roue_montage.fr.php
I'm sorry, everything is in french :/
If you have any problem to translate, ask to me !
Check here :
